73-79 ford truck parts - Planet 4x4
Go Back   Planet 4x4 > Planet 4x4 Classifieds > Vehicles and Trailers
Vehicles and Trailers Sell your 4x4's, Tow Rigs and Trailers here!
Reply
Thread Tools Display Modes
Old 01-24-2009, 10:25 AM   #1
beazer
beazer's Avatar
i have for sale parts for ford trucks off of a 74 ford f250 4x4
1) a/c cab with unit has body work started needs floor pan welded back in(have
replacements)free
2) full front clip make offer
3) 205 divorced transfer case obo
4) 3/4 ton 4x4 front end its a dana 44 with 409 gears and drum brakes
(brakes/leafs/hubs not included, hubs are brand new never been run cost
$100 will sale for the same price)axle best offer
5) 5 speed military transmission i believe it to be out of a 2 1/2 ton 4x4.
good for rock crawler or trail runner. $500
6) drive lines rear and intermidiate make offer
all up for trades as well. need cutting torch set or a winch or what ever let me know.
can send pics if needed they are in nampa
beazer is offline   Reply With Quote
Join Planet4x4! It's Free!
Join Planet4x4 For Free! If this is your first visit to Planet4x4 please take the time to join us .
Registering is required for you to post on the forums. Joining us will also give you the ability to track messages of interest, send private messages to other users, search our forums, view attachments, and take advantage of the many other contents of Planet4x4.net! It's free and takes just a few seconds to complete.
Click here to join our community!
If you are already a member of Planet4x4, please login above to gain full access to the site.
Sponsored Links
Advertisement
Old 02-01-2009, 12:08 AM   #2
orangeburban
orangeburban's Avatar
Re: 73-79 ford truck parts
what are you looking to get out of that frontend? i need to put discs on the 73, looks like it is going back to daily driver status,
thanks for the front axle by the way, you might want to take it off the ad.
orangeburban is offline   Reply With Quote
Old 02-01-2009, 12:20 AM   #3
shtmtlman
Spotter
shtmtlman's Avatar
John, i soooo wish i could use that tranny, super duper granny gear lol.
shtmtlman is offline   Reply With Quote
Old 02-01-2009, 10:51 AM   #4
Clydesdale4x4
Clydesdale4x4's Avatar
What would the tranny bolt too?
Clydesdale4x4 is offline   Reply With Quote
Old 02-01-2009, 06:39 PM   #5
beazer
beazer's Avatar
the front end has drum brakes, and i still have it, sold you the drive line lol
Old 02-01-2009, 06:40 PM   #6
beazer
beazer's Avatar
probably anything was from 21/2 ton military truck, and it was fabbed into my 1974 f250 4x4,390 devorced 205
Old 02-01-2009, 08:58 PM   #7
orangeburban
oh ok your ad says discs,
Old 02-01-2009, 09:21 PM   #8
Clydesdale4x4
So.. if you had it fabbed to an FE block.. then I should be able to bolt it to a FE block, right?
Old 02-02-2009, 05:43 AM   #9
beazer
beazer's Avatar
yes all you need to do is drill the twobottom holes in your bell houseing(the one that was there a friend needed). the trans has been drilled and tapped for this. i have a custom buit crossmember(located at someone elses place) that holds the trans. the only other mod i can thinkof is a small nothch in the cab to accomadate the new shift tower and shifter.
Old 02-02-2009, 06:14 AM   #10
Clydesdale4x4
what are the gear ratios?
Old 02-02-2009, 04:11 PM   #11
beazer
beazer's Avatar
on the trans? im not sure
Old 02-02-2009, 06:10 PM   #12
shtmtlman
Spotter
shtmtlman's Avatar
I don't know the ratio either, but i remember driving those trucks in the Army and low, is very low, lower than your typical granny gear.
Old 02-02-2009, 06:46 PM   #13
Clydesdale4x4
I guess that is what I was getting at, out of granny it behaves like a normal trans, and 5th is either 1:1 or an O/D?
Old 02-02-2009, 06:47 PM   #14
shtmtlman
Spotter
shtmtlman's Avatar
Yeah something like that lol.
Old 02-02-2009, 08:50 PM   #15
Nukegumby
Nukegumby's Avatar
Though I've only heard of the Spicer 3053A being used on deuce and a halfs, there are 3 Spicer trannys which are closely related. I'm including all their gearing, just in case.
I'll certainly be interested in learning how if someone can figure out the method for getting one of these married to a modern engine. Considering all the machining and body work I've seen here, though, I don't doubt that there's someone up to the challenge.
Spicer:__16.5" case______3053A________3053B____
1st---------5.90-----------6.00-----------4.5
2nd---------3.10-----------3.30-----------2.5
3rd---------1.70-----------1.89-----------1.5
4th---------1.00-----------1.00-----------1.0
5th---------0.85-----------0.85-----------0.75
rev----------??------------5.90------------??
Nukegumby is offline   Reply With Quote
Old 02-02-2009, 09:29 PM   #16
shtmtlman
Spotter
shtmtlman's Avatar
The tranny was in a running truck, with a 390.
Old 02-03-2009, 06:21 PM   #17
beazer
beazer's Avatar
sorry ron it was actually a 360 but yes running and driving. low gear and low in t case you can walk faster that it will move at 3500 rpm. in fifth gear at 65-70 2200rpm was all the motor was running....this was a daily driver turned project turnd parts lol.
Old 02-03-2009, 07:06 PM   #18
Clydesdale4x4
Interested in both it and the 205... cash flow is a serious issue right now..
Old 02-03-2009, 07:16 PM   #19
beazer
beazer's Avatar
always open to a good trade my man, ill through the intermedate shaft for free...dont know if its stock or custom...and that crossmember once i get it back from the frame i gave away lol
Old 02-03-2009, 10:03 PM   #20
Clydesdale4x4
PM sent....
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
