Geo Tracker Build Thread - Planet 4x4
Go Back   Planet 4x4 > Brand Loyalty > Suzuki
Suzuki Zuk nuts
Reply
Thread Tools Display Modes
Old 06-01-2009, 10:37 PM   #1
GeoTracker90
GeoTracker90's Avatar
By popular demand here is a build thread for what has been done on the Tracker to date.
Custom Air Intake
http://www.planet4x4.net/forums/showthread.php?t=5477
Lower A-arm Bracket Brace
http://www.planet4x4.net/forums/showthread.php?t=5845
Rocker Replacement / Sliders
http://www.planet4x4.net/forums/showthread.php?t=6677
In Frame Overhaul
http://www.planet4x4.net/forums/showthread.php?t=6880
GeoTracker90 is offline   Reply With Quote
Join Planet4x4! It's Free!
Join Planet4x4 For Free! If this is your first visit to Planet4x4 please take the time to join us .
Registering is required for you to post on the forums. Joining us will also give you the ability to track messages of interest, send private messages to other users, search our forums, view attachments, and take advantage of the many other contents of Planet4x4.net! It's free and takes just a few seconds to complete.
Click here to join our community!
If you are already a member of Planet4x4, please login above to gain full access to the site.
Sponsored Links
Advertisement
Old 06-01-2009, 11:03 PM   #2
GeoTracker90
Re: Geo Tracker Build Thread
Continued:
Tube Doors
http://www.planet4x4.net/forums/showthread.php?t=6931
3" A-arm Drop Brackets (Not Completed)
http://www.planet4x4.net/forums/showthread.php?t=7032
Clutch Issues - Round #1
http://www.planet4x4.net/forums/showthread.php?t=7287
3/4" Drive Line Spacer (Home Built)
http://www.planet4x4.net/forums/showthread.php?t=7511
Custom 2" Trailer Hitch
http://www.planet4x4.net/forums/showthread.php?t=7599
2" Body Lift, Coil Spacers, 15X8 Wheels, 31X10.5R15 Tires
http://www.planet4x4.net/forums/showthread.php?t=7979
Clutch Issues - Round #2 Hydraulic Conversion
http://www.planet4x4.net/forums/showthread.php?t=10827
2" Gas Tank Lift
http://www.planet4x4.net/forums/showthread.php?t=12786
Old 08-20-2009, 08:09 AM   #3
The Torch
The Torch's Avatar
Our 95 Tracker got bent. Took a hit in the drivers side front clip.
I'm thinking about cutting off the IFS and rear stock axles and mounting up some solid axles.
I'm thinking about using stock Jeep axles... that way I could pass tires and wheels to the Tracker from my Jeep.... or both might run the same size eventually....
I've questions about which axles to look for. The 20's and 30's are cheap and might work because the Trackers carry so much less weight from the start....
Any thoughts on this? Know anyone who has done this?
The Torch is offline   Reply With Quote
Old 08-20-2009, 08:15 AM   #4
landtortise89
landtortise89's Avatar
i would honestly run yota axles if I was going to do it.
landtortise89 is offline   Reply With Quote
Old 11-07-2009, 11:44 AM   #5
idayota
idayota's Avatar
any updates? solid axle yet? :-)
idayota is offline   Reply With Quote
Old 11-09-2009, 08:11 AM   #6
GeoTracker90
Nope, not yet, but the body may be making a migration over to a Toyota IFS chasis some time this winter. Plan is to keep the Toyota drivetrain for now. Any one want to buy a reasonably fresh 1.6L motor?
Mike
Old 11-11-2009, 05:23 PM   #7
sj410
Riding Shotgun
sj410's Avatar
8 or 16 valve?
sj410 is offline   Reply With Quote
Old 11-11-2009, 06:35 PM   #8
Mope
Mope's Avatar
If it's a 1990, it should be an 8v
Mope is offline   Reply With Quote
Old 11-12-2009, 08:13 AM   #9
freeriders98
freeriders98's Avatar
How much for the motor mike. My little smokey is in need of an upgrade from hamsters to squirrels!
freeriders98 is offline   Reply With Quote
Old 11-12-2009, 08:29 AM   #10
GeoTracker90
Correct, it is the 8 valve.
Motor has been sold.
Mike
Old 01-25-2010, 09:38 PM   #11
GeoTracker90
I figured that I should update this thread with the latest activity:
Tracker Transformation
http://www.planet4x4.net/forums/show...161#post126161
Mike
Old 07-08-2012, 12:04 PM   #12
GeoTracker90
I just needed to bump this back up to the front page so that I can find it easier again.
Mike
Old 10-15-2012, 09:37 AM   #13
The Torch
The Torch's Avatar
Welllll, at last update we know you sat the body on a yota frame... BUT there was SNOW on the ground at the time... meaning: That was almost a YEAR AGO... so whazzup?
Any new info?
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
